方法
ArcGIS Pro で異なるスキーマを持つフィーチャクラスを追加する
Last Published: September 6, 2023
サマリー
In ArcGIS Pro, it is possible to append multiple input datasets into an existing target using the Append tool. The Append tool does not append two or more feature classes of different schemas by default. This article provides the instructions to append feature classes that have different schemas in ArcGIS Pro.
手順
  1. Create a new feature class and specify its template dataset using the schemas of all the feature classes to be appended.
    1. Open the ArcGIS Pro project. On the top ribbon, click the Analysis tab > Tools.
    2. In the Geoprocessing pane, search for Create Feature Class (Data Management), and click it. The Create Feature Class window opens. In the Create Feature Class window, click Parameters.
    3. Specify the location of the feature class in Feature Class Location.
    4. Specify a name for the feature class in Feature Class Name. In this example, it is NewFeatureClass.
    5. For Geometry Type, select the geometry type of the feature classes to be appended. In this example, Polyline is selected.
    6. For Template Dataset, select the feature classes to be appended. In this example, USA_water_lines_dcw and washington_highway are selected.
    7. Click Run.
The Create Feature Class window displaying the Feature Class Location, Feature Class Name, Geometry type and Template Dataset parameters.
  1. Append the desired feature classes to the created feature class in Step 1.
    1. On the top ribbon, click the Analysis tab > Tools.
    2. In the Geoprocessing pane, search for Append (Data Management), and click it. The Append window opens. In the Append window, click Parameters.
    3. For Input Datasets, select all the feature classes to be appended. In this example, USA_water_lines_dcw and washington_highway are selected.
    4. For Target Dataset, select the created feature class in Step 1. In this example, NewFeatureClass is selected.
    5. For Field Matching Type, select Use the field map to reconcile field differences.
    6. Configure the parameters under Field Map. Refer to ArcGIS Pro: Attribute field mapping for more information.
    7. Click Run.
The Append window displaying the Input Datasets, Target Dataset and Field Matching Type parameters.
記事 ID: 000025987
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
