方法
A web map disclaimer highlights important information such as copyrights and functions as a reminder, thereby creating awareness among users. A disclaimer can be added to a web map in several ways. Refer to How To: Add a disclaimer to a web map for more information.
This article provides the workflow to add a disclaimer to a web map using a sketch layer in ArcGIS Online Map Viewer.
In ArcGIS Online Map Viewer, there are two methods to add disclaimers to a web map using sketch layers.
Add the disclaimer using a text feature
This workflow is suitable for short, one-line disclaimers, as the map text area is limited. In Map Viewer, add the disclaimer text to the web map by adding it as a text feature.
, and select Open in Map Viewer.Note: Use multiple text lines to organize long sentences.
The image below shows the disclaimer displayed as a text feature in ArcGIS Online Map Viewer.
Add the disclaimer using a stamp feature
This workflow is suitable for concise, multiple-line disclaimers, as the text can be inserted without adjusting its position to fit the data frame. The disclaimer is added to the web map as a pop-up that only displays after the stamp feature is clicked.
In Map Viewer, add a stamp feature to the web map and configure the pop-up of the stamp feature to add the disclaimer text.
The image below shows the stamp pop-up disclaimer displayed in ArcGIS Online Map Viewer.
記事 ID: 000026618
ArcGIS エキスパートのサポートを受ける
今すぐチャットを開始
