PROCÉDURE
In some instances, it is necessary to split a circular area in half to set a boundary or to divide features into equal parts. The image below shows a circle with its attribute table before it is split. The total area is approximately 6,499,608.21 square meters.
Follow the workflow below to split a circle polygon in half using the Divide tool in ArcGIS Pro.
Note: To split a circle polygon in half in ArcMap, refer to How To: Split a circle polygon into half in ArcMap.
ID d’article: 000023082
Commencez à discuter maintenant
