PROCÉDURE
importer une image en tant que style dans ArcGIS Pro
Last Published: July 18, 2025
Résumé
In ArcGIS Pro, features are symbolized using the default Esri symbol sets. If custom symbology is required, it is possible to import an image as a picture marker symbol under the Style option and use the image as a style in the map.
Procédure
The following steps describe how to import an image to ArcGIS Pro as a style:
  1. In ArcGIS Pro, open a new blank project.
  2. Creating a personal style for custom symbols is recommended. To create a new style, refer to ArcGIS Pro: Create a style in the project.
  3. In Catalog, click the Styles drop-down list and select the newly created style. Right-click the style and select Manage.
User-added image
  1. Right-click the empty space and select New.
User-added image
  1. By default, the Point symbol appears. Click Point symbol to edit.
  2. In the Point symbol pane, set the desired Name and Key. Click Apply.
User-added image
  1. Click Properties.
  2. Click the Layers icon and select Picture marker from the drop-down list.
  3. Under the Appearance drop-down list, click File to select the image. If necessary, adjust the Position, Rotation, and Offset Distance. Click Apply.
User-added image
To apply the new symbol to a layer, click the layer symbology in the Contents pane to open the Symbology pane. The picture marker symbol created using the above steps is available under the newly created style section.
User-added image
ID d’article: 000019909
Obtenez de l'aide avec l'IA
Résolvez rapidement votre problème avec le chatbot Esri Support AI.
Commencez à discuter maintenant
Informations associées
En savoir plus sur ce sujet
