Preguntas frecuentes
¿Cuáles son las versiones de producto compatibles con el dataset de mosaico creado en ArcGIS Pro y otro software de ArcGIS?
Last Published: September 14, 2023
Respuesta
Esri recommends creating and editing mosaic datasets in the ArcGIS Pro version compatible with the other versions of ArcGIS software. The table below lists the product version compatibility of the mosaic dataset created in ArcGIS Pro and other ArcGIS software.
ArcGIS Pro Version
ArcGIS Enterprise, ArcGIS Server, and ArcMap Version
2.610.8.1
2.510.8
2.410.7.1
2.310.7
2.210.6.1
2.110.6
2.010.5.1
1.410.5
1.310.4.1
1.210.4
1.110.3.1
1.010.3
Alternatively, upgrade the mosaic dataset version created in an older version of ArcGIS Pro by editing it using a newer version of ArcGIS Pro.
For example, if a mosaic dataset is created using ArcGIS Pro 2.3, editing it using ArcGIS Pro 2.5 upgrades the version of the mosaic dataset. This mosaic dataset is compatible with ArcGIS 10.8 or ArcGIS 10.8.1. including ArcGIS Enterprise, ArcGIS Server, and ArcMap.
Id. de artículo:000020432
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
Información relacionada
Descubrir más sobre este tema
