HOW TO
In ArcGIS Pro, a bookmark is a shortcut to a location on a map or perspective in a scene that users can return to or share with others. Bookmarks can be used to produce keyframes for animations or pages for a bookmark map series. However, the scale is not retained when bookmarks are created from a map and used as the bookmark map series in the layout.
The image below shows the scale of bookmarks is not retained in a map series.
This article provides another alternative to retain the scale of bookmarks in a map series in ArcGIS Pro.
The image below shows the scale of bookmarks retained in a map series.
Article ID: 000028269
Get help from ArcGIS experts
Download the Esri Support App
