English
Error: Code 403: You do not have permissions to access this resource or perform this operation
Error Message
In some instances, when attempting to submit an ArcGIS Survey123 form for sharing with an organization, the action fails and the following error message is returned:
Error:
Code 403
You do not have permissions to access this resource or perform this operation.
Error Code 403 You do not have permissions to access this resource or perform this operation​​
Cause
The owner of the user account is not a member of the organization.
Solution or Workaround
To resolve the error, ensure the owner of the user account is a member of the organization. If the issue persists, check the sharing settings of the survey to ensure the member has sufficient permissions to submit a survey. Refer to ArcGIS Survey123: Share your survey for more information.
Related Information
Last Published: 1/10/2022
Article ID: 000026969
Software: ArcGIS Survey123 3.9, 3.8, 3.7, 3.6, 3.5, 3.4, 3.3, 3.2, 3.13, 3.12, 3.11, 3.10, 3.1, 3.0, 2.9.Classic, 2.8
