PROBLEM
In Portal for ArcGIS, some or all analysis tools are missing in Map Viewer.
Configure the ArcGIS Enterprise portal to perform analysis
Upgrade the portal's hosting server with an ArcGIS GIS Server Advanced edition. Refer to ArcGIS Server: Functionality for more information
Configure utility services for the desired tools
Some utility services need to be enabled before the analysis tool are available. Refer to Portal for ArcGIS: Configure utility services for steps to do so.
Alternatively, an ArcGIS Enterprise portal can be configured to use ArcGIS Online utility services. Refer to Portal for ArcGIS: Configure ArcGIS Online utility services for steps to do so.
Grant the Publisher or a custom role with spatial analysis privileges enabled to perform analysis
An ArcGIS Enterprise portal member requires the Publisher or a custom role with spatial analysis privileges enabled to perform analysis. Refer to Portal for ArcGIS: Configure member roles for steps to do so.
Configure a GIS Server site as the portal's hosting server
A GIS Server site configured with a data store needs to be set as a hosting server for the portal to perform feature and raster analysis in Map Viewer. Refer to Portal for ArcGIS: Configure a hosting server for steps to do so.
Get help from ArcGIS experts
Download the Esri Support App
