PROBLEM
Unable to import an SSL certificate into ArcGIS Data Store
Last Published: November 23, 2021
In some instances, when attempting to use the command prompt to import a self-signed Secure Sockets Layer (SSL) certificate into ArcGIS Data Store, a Usage error is returned in the prompt as below:
Error:
<certificatename> is not recognized as an internal or external command, operable program or batch file.
The following error is also returned in the ArcGIS Portal Administrator Directory when attempting to import the same certificate into Portal for ArcGIS:
Error:
Unable to import certificate. Code: 500
Cause
This issue happens when non-alphanumeric characters and non-English characters are used in the SSL certificate password, causing the importation of the certificate to fail.
Alphanumeric characters consist of letters and numbers only.
Solution or Workaround
To resolve the issue, create an SSL certificate with alphanumeric passwords, and avoid characters specific to non-English locales. Refer to ArcGIS Enterprise: Replace ArcGIS Data Store SSL certificate for steps to update the ArcGIS Data Store SSL certificate.
Article ID:000026043
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
