PROBLEM
The Time Settings option is not available in ArcGIS Online
Last Published: June 4, 2021
In ArcGIS Online, when a map contains a time-enabled layer, the map display can be configured to present the changes in the data over time. The layer can be time-enabled using the Time Settings option on the item details page. However, in some instances, the Time Settings option is not available on the layer's item details page.
The item details page, under Overview, with the Time Settings option not visible.
Cause
The date field is not available in the hosted feature layer. A date field is required to enable the time settings on a hosted feature layer.
Columns displaying the Fields view of the hosted feature layer data, and no date field under the Type column.
Solution or Workaround
Only the owner of the hosted feature layer or a user with Administrator privileges can perform the following workflow.
To resolve this issue, add a new date field to the published hosted feature layer. Refer to ArcGIS Online: Add a field for the workflow. For Type, click the drop-down arrow, and select Date.
Window to access the drop-down menu by clicking the down-arrow next to the box for Type.
After a new date field is created and added to the hosted feature layer, the Time Settings option is available on the item details page. To enable time on the layer, refer to ArcGIS Online: Enable time on layers for instructions.
Three columns displaying the Fields view of the hosted feature layer data with a new date field added.
The item details page, under Overview, with the Time Settings option visible.
Article ID:000025594
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
