HOW TO
Layers can be time-enabled to highlight changes in data over time. This can be anything from population change to crime rates, using animation to demonstrate these changes over time.
Time-enabled layers can be created in ArcGIS Desktop (ArcMap or ArcGIS Pro) or ArcGIS Online. These layers can be added to a web map or used to create a web application to share the time animation. This can be achieved with the Media Map template in Configurable Apps.
Follow the steps below to enable time on layers in ArcGIS Online and turn the web map into a web app.
Note: To enable time settings on a layer, the layer must be published to ArcGIS Online with a date field. The Time Settings option is unavailable if a hosted feature layer does not have a date field.
Note: When a time-enabled layer is added to a web map, time animation and time settings are enabled.
Article ID: 000024836
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
