HOW TO
Count the number of polygon features within a polygon in ArcMap and ArcGIS Pro
Last Published: May 24, 2021
Summary
Counting the number of polygon features within a polygon is a basic and useful statistic when performing spatial analysis. The image below shows a polygon layer of a hypothetical region in the city of Columbus, and another polygon layer of historic neighborhoods within it.
Map configured in ArcGIS Pro containing polygon features within a polygon.
This article provides the instructions to determine the number of historic neighborhoods in the region using the Spatial Join tool in ArcMap and ArcGIS Pro.
Procedure
In ArcMap
  1. Navigate to ArcToolbox > Analysis Tools > Overlay > Spatial Join. The Spatial Join window opens.
ArcToolBox contains a set of tools that perform the fundamental GIS operations.
  1. In the Spatial Join window, fill in the required fields and parameters as follows:
    1. Target Features: The target polygon layer. In this example, the target polygon layer is Columbus_region.
    2. Join Features: The polygon features found within the target polygon layer. In this example, the input is Historic_neighborhood.
    3. Join Operation (optional): Select JOIN_ONE_TO_ONE and check the Keep All Target Features (optional) check box.
    4. Match Option (optional): Select COMPLETELY_CONTAINS.
    5. Leave the other parameters as default.
    6. Click OK to run the tool.
The Spatial Join tool pane to calculate the number of polygon features within the target polygon layer in ArcMap.
  1. In the Table Of Contents pane, browse to and right-click the output layer, and select Open Attribute Table.
  2. In the attribute table, look for the Join_Count field. The number in the field represents the number of polygon features within the target polygon layer, which in this example is the number of historic neighborhoods in the hypothetical region of the city of Columbus.
The Join_Count field found in the attribute table of the output layer.
In ArcGIS Pro
  1. Navigate to the Geoprocessing pane. Click Toolboxes > Analysis Tools > Overlay > Spatial Join.
  2. In the Spatial Join window, on the Parameters tab, fill in the required fields and parameters as follows:
    3. Join Operation: Select Join one to one and check the Keep All Target Features check box.
    4. Match Option: Select Completely contains.
    5. Leave other parameters as default.
    6. Click Run to run the tool.
The Spatial Join tool to find the number of polygons within the polygon layer in ArcGIS Pro.
  1. In the Contents pane, browse to and right-click the output layer, and select Attribute Table.
Article ID: 000025573
Software:
  • ArcMap
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
