Frequently asked question
No, it is not possible to publish a joined layer to ArcGIS Online as it is not a permanent layer. The joined layer is saved with the feature layer in the map document or map file but it is not saved in the data source of the layer.
When attempting to publish the joined layer from ArcMap to ArcGIS Online, fields created from the joined layer are not displayed in the attribute table of its hosted feature layer. In ArcGIS Pro, attempting to publish a joined layer to ArcGIS Online returns an error message, '00226: In-memory joins and relates are not supported.'
However, the joined layer can be exported as a database feature class in ArcGIS Pro or ArcMap, and published to ArcGIS Online. The following are steps to export the joined layer and publish it to ArcGIS Online.
In ArcGIS Pro
In ArcMap
Alternatively, use the Join Features tool in ArcGIS Online Map Viewer to create a new joined layer between the feature layers. Refer to FAQ: Does ArcGIS Online support joins and relates? for more information.
Get help from ArcGIS experts
Download the Esri Support App
