Is This Content Helpful?
How can we make this better? Please provide as much detail as possible.
Contact our Support Team
The ArcGIS Field Maps mobile app is registered and supported with an ArcGIS Enterprise 10.8.1 deployment and higher. If working with ArcGIS Enterprise versions 10.6.1 to 10.8, the following procedure is required to add ArcGIS Field Maps as a registered application within an ArcGIS Enterprise deployment.
Use the following steps to add ArcGIS Field Maps as a registered app to an ArcGIS Enterprise 10.6.1 deployment and later:
https://webadaptorhost.domain.com/webadaptorname/sharing/rest
Note: The URL below must be manually typed into the address bar and cannot be accessed by clicking through the Sharing/REST web interface. In the following URL, [username] should be replaced with the aforementioned administrative member.
http://webadaptorhost.domain.com/webadaptorname/sharing/rest/content/users/[username]
["urn:ietf:wg:oauth:2.0:oob", "arcgis-fieldmaps://auth/"]
https://webadaptorhost.domain.com/webadaptorname/portaladmin
Last Published: 4/7/2021
Article ID: 000024488
Software: Portal for ArcGIS 10.8.1, 10.8, 10.7.1, 10.7, 10.6.1, 10.6
