HOW TO
This article describes the solution to BUG-000130541. BUG-000130541 causes a portal item's thumbnail to become corrupted and display as pink after upgrading from ArcGIS Enterprise version 10.6.1 to 10.7 or later.
The upgrade from ArcGIS Enterprise 10.6.1 to version 10.7 or later changes the mechanism by which thumbnail images are loaded and processed. This uncovered a latent bug in how thumbnails are generated by ArcGIS Pro 2.5 and prior. The related ArcGIS Pro bug is BUG-000129503.
The corrupted thumbnails cause administrative commands and tools such as the WebGIS DR tool (webgisdr) to fail, returning the following error message:
"{"code":500,"messages":["Export operation failed. Unsupported Image Type"],"status":"error"}".
These instructions and the attached script are the resolution to BUG-000130541. The provided script finds and fixes the corrupted thumbnails. Once the thumbnails are corrected, the WebGIS DR tool and other commands that may have failed due to a corrupted thumbnail work as expected.
The thumbnails are corrupted because they are incorrectly saved as a JPG files with incompatible alpha channel values. The script provided in the link below fixes the corrupted thumbnails by performing an update of the thumbnails by replacing them with an image in PNG format. It is necessary to download a generic image to use as a thumbnail in PNG format. Before running the script, provide the path to this PNG as an input parameter.
Note: Note that the script will update the thumbnails of all services, however the thumbnail is only displayed in ArcGIS Server Manager, not in Portal for ArcGIS, so only Administrators and Publishers can see the generic thumbnail.
baseURL = "https://<machine>.domain.com:6443/arcgis" username = "username_admin" password = "password_admin" thumbnailPath = r"C:\Users\example\pictures\sample.png"
C:\python27\ArcGISx6410.8\python.exe C:\temp\<file_name>.py
The output reports all of the thumbnails that were updated. Once complete, run exportSite, importSite, the WebGIS DR tool, or any other operation and it should succeed.
Get help from ArcGIS experts
Download the Esri Support App
