Frequently asked question
ArcGIS Pro allows the publishing of various data types to ArcGIS Online and ArcGIS Enterprise using several options. Refer to ArcGIS Pro: Share with ArcGIS Pro for more information on sharing data.
In some instances, when publishing a feature class containing a related table from ArcGIS Pro to ArcGIS Online, the table is not retained. This issue occurs if the feature class is shared through an incorrect process, for example, if the feature class is shared through the Contents pane.
To correctly retain the related table when publishing a feature class to ArcGIS Online, publish all the layers in the map as a web layer using the steps provided below.
To view the related records in ArcGIS Online, open the hosted feature layer in the item details page, and click Open in Map Viewer. Click any feature on the map, and click Show Related Records in the pop-up. Records from the related table of the selected feature are displayed in the attribute table.
Article ID: 000023738
Get help from ArcGIS experts
Download the Esri Support App
