ERROR
When working with utility networks in ArcGIS Pro, attempting to run the Add Rule or Import Rule geoprocessing tool may return the following error message:
Error: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds. Unexpected operation [Error updating row from table ..UN_6_Props] Unexpected operation [Error updating row from table ..UN_6_Props] Failed to execute (AddRule)
This error is displayed when the existing enterprise geodatabase connection in the ArcGIS Pro project has the versioning type set to Traditional instead of Branch in the Geodatabase Connection Properties window.
Set the enterprise geodatabase connection to the Branch versioning type in Geodatabase Connection Properties.
Article ID: 000023667
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
