HOW TO
Instructions provided describe how to use ground control points (GCPs) in the Site Scan Manager for ArcGIS web application.
When collecting drone imagery, it is often helpful to use ground control points (GCPs) to ensure the image collection has high accuracy. Given the extremely small pixels of drone imagery, highly accurate GCPs may be required, depending on the project. Using a real-time kinematic positioning (RTK) GPS unit to create GCPs is a best practice to collect geographically accurate drone imagery. This how-to guide demonstrates the process for adding RTK GCPs to Site Scan Manager.
Collect ground control points
Upload ground control points to Site Scan Manager
Select a known or custom coordinate system
By default, WGS 84 is selected, but an EPSG code can be entered to find a coordinate system, or choose to use a custom coordinate system.
If using a custom coordinate system
This process is used to place the GCPs over the orthomosaic to choose the right photos for the control point.
Tag points in photos – smart GCPs
Use checkpoints (optional)
After tagging the photos to the GCPs, it may be desirable to use some control points as checkpoints. Checkpoints are not used to enhance the accuracy of the output, but to independently measure the accuracy of the results by comparing the surveyed location of the control points to their location in the processed outputs.
Note: - Checkpoints must only be used if there are at least five other points available for use as GCPs. - Checkpoints must be inside the site boundaries, and not on the corners. - To obtain the most conservative accuracy values, place checkpoints as far from GCPs as possible. - After validating accuracy with checkpoints, reprocess the flight using all points as GCPs to further enhance accuracy.
The image below shows an ideal ground control and checkpoint layout on a 40-acre site, using eight GCPs and five checkpoints. GCPs are displayed in green, and checkpoints in red.
Confirm and process
Begin processing after tagging at least two GCPs each in two photos. For best results, Esri recommends tagging at least five GCPs in four to five photos each. Click the Process button to process with GCPs.
Analyze and export
With georeferenced orthomosaics, Site Scan for ArcGIS Manager’s analysis tools become even more powerful. The Overlay, Compare Flights, and Measurements tools benefit from the improved accuracy of georeferencing. Additionally, the orthomosiacs, DEMs, and point clouds (.las) are georeferenced in the desired coordinate system.
Article ID: 000023040
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
