HOW TO
Some workflows require importing bookmarks from ArcGIS Pro to ArcMap to ensure the same extent and location are applied in both software. However, this cannot be done directly as the bookmark format of ArcGIS Pro is not backward compatible with ArcMap; ArcGIS Pro uses the .bkmx bookmark file format, while ArcMap uses the .dat bookmark file format. The bookmarks are modelled differently, and the properties are not the same. A workaround is to replicate bookmarks from ArcGIS Pro to ArcMap through ArcGIS Online with an organizational account.
Complete the steps below to replicate bookmarks from ArcGIS Pro to ArcMap.
Article ID: 000022846
Get help from ArcGIS experts
Start chatting now
