HOW TO
The Create Fishnet tool creates a fishnet of rectangular cells within a polyline or polygonal output feature. The Create Fishnet tool is useful for mapping areas, for instance when deciding on proper drilling locations. The tool creates rectangular grids representing possible borehole locations. In this scenario, the grids are created within the sandstone polygon and away from the polygon boundary in a specified distance using the Buffer tool.
Follow the instructions below to create rectangular grids within a polygon layer with sampling points away from the polygon boundaries in ArcGIS Pro.
Note: Template Extent automatically changes to As Specified Below when the polygon feature is selected.
Note: Optionally, set zero as the values for Cell Size Width, Cell Size Height, Number of Rows and Number of Columns to automatically calculate numbers of rows and columns. However, when values are entered for Cell Size Width and Cell Size Height, the Number of Rows and Number of Columns text boxes automatically close.
The image below shows the output of the Create Fishnet tool with the rectangular grids.
The image below shows the output of the Clip tool.
The image below shows the output of the Buffer tool.
The image below shows the sandstone polygon layer with sampling points 50 meters away from the surrounding sandstone polygon boundaries.
Note: Optionally, open the attribute table, add a new field and use the Calculate Field (Data Management) tool to label the points as shown in the image below. Refer to ArcGIS Pro: Add Field (Data Management) and ArcGIS Pro: Fundamentals of field calculations for more information.
Article ID:000022784
Get help from ArcGIS experts
Download the Esri Support App
