BUG
Unable to perform editing/administration workflows when accessing a utility network from an ArcGIS Enterprise 10.6.x portal using ArcGIS Pro 2.4
Certain editing and administration workflows return an error when accessing a utility network from an ArcGIS Enterprise 10.6.x portal using ArcGIS Pro 2.4. A wide variety of symptoms are experienced when working with these ArcGIS Pro and ArcGIS Enterprise versions.
Here are a few examples:
  • Attempting to view the Network Properties results in the following error:
Utility Network unavailable
  • Enabling the network topology returns the following error:
Error 001793: Network topology must be enabled.
  • Using the Modify Associations pane: associations are not populated.
  • Executing Update Subnetwork returns the following error:
Cause
This is an ArcGIS Pro client-side compatibility issue; when accessed from an ArcGIS Enterprise 10.6.x portal, ArcGIS Pro 2.4 clients are not supporting backward compatibility for working with utility networks .
Workaround
This is resolved in the ArcGIS Pro 2.4.2 patch. For more information, see ArcGIS Pro Release notes.
The following workarounds are available:
  • Downgrade ArcGIS Pro to the latest 2.3.x release available
  • Upgrade ArcGIS Enterprise to 10.7.x or later
Article ID: 000021681
Software:
  • ArcGIS Server
  • ArcGIS Pro 2 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
