HOW TO
Convert a polygon Z geometry to a polygon geometry shapefile in ArcGIS Pro
Summary
The instructions provided describe how to convert a polygon Z geometry to a polygon geometry shapefile in ArcGIS Pro. The following image is an example of a polygon Z geometry shapefile.
Polygon Z geometry shapefile
Procedure
  1. Open the Feature Class to Shapefile geoprocessing tool.
    1. On the Analysis tab, click Tools.
    2. In the Geoprocessing pane, click the Toolboxes tab, and expand Conversion Tools > To Shapefile, and click Feature Class to Shapefile.
Expanded Conversion Tools drop-down showing To Shapefile
  1. In the Feature Class To Shapefile dialog box, specify the following:
    1. In the Geoprocessing pane, click the Parameters tab and select the polygon Z geometry feature layer to be converted for Input Features. Set the Output Folder to where the output shapefile will be written.
    2. Click the Environments tab and under Output has Z Values, select Disabled.
    3. Click Run.
Geoprocessing pane showing Parameters tab and Environments tab
  1. Open the new shapefile by adding it to the map. In the Contents pane, right-click the new feature layer and select Attribute Table. The shapefile is now a polygon geometry shapefile.
Article ID:000021489
Software:
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
