Frequently asked question
Yes, it is possible to view a geopoint location from ArcGIS Survey123 Connect in Google Maps, and several methods are described below.
Use an expression in the ArcGIS Survey123 Connect application
The expression containing the pulldata() function is added to the XLSForm. However, this process only works in the ArcGIS Survey123 application and not in the browser.
concat('<a href="https://www.google.com/maps?daddr=',pulldata ("@geopoint", ${geopoint_name}, "y"), ',' ,pulldata("@geopoint", ${geopoint_name}, "x"), concat('&ll=">Click to open</a>'))
In Form Preview in the ArcGIS Survey123 Connect application, select the desired location in Location Selector and select Click to open to view the location in Google Maps.
Use an online map in the survey
The default basemap in the ArcGIS Survey123 Connect map setting can be changed from the ArcGIS Survey123 field app in the menu on the map page of the survey. To change the basemap, a URL must be added to the survey .info file. For more information, refer to ArcGIS Survey123: Use an online map in your survey.
Article ID: 000020786
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
