HOW TO
Configure the hosted scene layer pop-up in an ArcGIS Online web scene
Summary
ArcGIS Online does not provide the ability to configure a hosted scene layer pop-up in a web scene. However, it is possible to configure the pop-up of the related hosted feature layer to reflect in the hosted scene layer and show attributes in a web scene.
A hosted scene layer uses the pop-ups configured on the related hosted feature layer. For more information, refer to Publish hosted scene layers.
Procedure
To configure the hosted scene layer pop-up, edit the related hosted feature layer pop-up in Map Viewer or through its Item Details page. The instructions provided describe both methods to configure the hosted scene layer pop-up in a web scene.
Configure the pop-up in Map Viewer
  1. In ArcGIS Online, open the hosted feature layer in Map Viewer.
  2. Configure pop-up. To configure the pop-up, refer to Configure pop-ups.
  3. Once pop-up configuration is completed, use the layer options to Save Layer. The new pop-up configuration is reflected in the hosted scene layer and can be viewed in the web scene.
Configure the pop-up in the item details page
  1. In ArcGIS Online, open the Item Details page of the hosted feature layer.
  2. Click the Visualization tab.
  3. Click the Configure Pop-up An image of the Configure Pop-up icon. icon, and configure the pop-up as desired.
  4. Click OK, and click Save Layer to save the changes. The edited pop-up configuration is reflected in the hosted scene layer and can be viewed in the web scene.
Alternatively, configure the pop-up for the layer in ArcGIS Pro before sharing to ArcGIS Online. For more information on configuring a pop-up in ArcGIS Pro, refer to Configure pop-ups. Publish the layer as a hosted scene layer from an ArcGIS Pro scene or a scene layer package. Once published, add the hosted scene layer to a web scene in ArcGIS Online and enable the pop-up for the layer to view the configured pop-up.
Article ID:000019514
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
