PROBLEM
When editing a hosted feature layer, such as in an ArcGIS Online map viewer or web app, the edits are not applied and the following error message is returned:
Error: Invalid object name
This is a known issue. This issue occurs if the 'Keep track of created and updated features' option is enabled and the 'Enable Sync' option is disabled in the hosted feature layer editor settings. For more information, refer to BUG-000112974.
The workaround for this issue is as follows:
Get help from ArcGIS experts
Download the Esri Support App
