PROBLEM
In some instances, when attempting to sync a map to work offline in Collector for ArcGIS (Windows), the point and polygon feature services do not appear on the map.
This is a known limitation. The problem occurs when using polygon and point feature services published from ArcGIS Pro, and is specific for Windows 10 devices. For more information, refer to BUG-000105146.
To resolve this issue, use one of the following options:
Save the polygon and point feature services in ArcGIS Online
Save each polygon and point feature service in the ArcGIS Online web map to update the JSON of the feature services.
Use ArcMap to publish the polygon and point feature services
Publish the polygon and point feature services from ArcMap referring to the following web help page, ArcGIS Online Help: Publish from ArcMap. Use the published polygon and point feature services to create a web map and sync the web map to work offline in Collector for ArcGIS (Windows).
Article ID:000019220
Get help from ArcGIS experts
Download the Esri Support App
