ERROR
Attempting to log in to an ArcGIS Enterprise portal using Collector for ArcGIS (Android) version 17.0.4 and above, or attempting to access the Portal for ArcGIS home page using an Android device, returns the following error message:
Error: The server you are trying to connect cannot be verified.
An Android device does not have the capability to bypass certificate authentication like a computer. By default, only certain certificate authority (CA) certificates that are pre-installed in Android operating systems meet Android security requirements. Therefore, the CA certificates used by Portal for ArcGIS must be installed manually in the Android device.
To check if the CA certificates used by Portal for ArcGIS are trusted on an Android device, refer to the Work with CA certificates (trusted credentials) section in Google Support: Add & remove certificates.
To establish trust between Collector for ArcGIS (Android) and Portal for ArcGIS, the CA certificates used by Portal for ArcGIS and the web server certificate must be installed in the Android device manually. To do so, follow the steps described below:
Note: Ensure the root certificate, and all the intermediate certificates are saved as files with .cer extension.
Note: Ensure this certificate is saved as a file with .pfx extension.
Article ID: 000017465
Get help from ArcGIS experts
Download the Esri Support App
