Error: The ArcGIS Server license is missing or not valid. Please provide the path to an authorization file (ECP file) that contains an ArcGIS Server License
Error Message
Attempting to connect to an enterprise geodatabase or SQL database failed and the following error is returned:
Error: The ArcGIS Server license is missing or not valid. Please provide the path to an authorization file (ECP file) that contains an ArcGIS Server License.
Cause
The keycodes file used as the Authorization File parameter in the Create Enterprise Geodatabase tool to create the connection to the database in ArcGIS Pro is expired. The default folder location for the keycodes file is as follows:
C:\Program Files\ESRI\License10.x\sysgen
The following image shows a sample of a keycodes file with the expiry date:
Solution or Workaround
Replace the expired ArcGIS Enterprise and enterprise geodatabase licenses with a new license containing the new expiry date. Refer to How To: Replace expired ArcGIS Server and enterprise geodatabase licenses for instructions.
Related Information
- ArcGIS Enterprise: Obtaining an authorization file
- ArcGIS Enterprise: Authorizing ArcGIS Server
- How To: Generate a keycodes file to authorize an enterprise geodatabase when an ArcGIS Server instance is unavailable
Last Published: 6/13/2022
Article ID: 000027828
Software: Portal for ArcGIS 10.9.1, 10.9, 10.8.1, 10.8, 10.7.1, 10.7 ArcGIS Server 10.9.1, 10.9, 10.8.1, 10.8, 10.7.1, 10.7
