Be The First To Get Support Updates
Want to know about the latest technical content and software updates?
How To: Create multiline labels in ArcGIS Online Map Viewer
Summary
In ArcGIS Online Map Viewer, multiline labels can be created using the Arcade custom expression builder. In this article's example, the California_Office_Branches layer contains information on the branches in California, as shown in the attribute table below.
Note: ArcGIS Online Map Viewer Classic does not support multiline labels.
The expression below is used to create a label displaying the Office_Size and Contact_Number field values on two separate lines for each office.
Note: The TextFormatting.NewLine constant inserts a line break between the two fields.
$feature["Office_Size"]+TextFormatting.NewLine+$feature["Contact_Number"]
Procedure
- In ArcGIS Online, open the layer in Map Viewer and enable labeling. For instructions, refer to Steps 1 through 6 of this help document: ArcGIS Online: Apply labels.
- In the Label features pane, click Add label class.
- Under Label field, click the Use expression
icon.
- In the editor window, in the Expression box, highlight the content and press Delete to clear the box.
- Build the expression.
- Click Globals, and click $feature["<field 1>"]. In this example, it is $feature["Office_Size"].
- Type +.
- Click Constants, and click TextFormatting.NewLine to add a line break.
- Type +.
- Click Globals, and click $feature["<field 2>"]. In this example, it is $feature["Contact_Number"].
- Click Test to verify the expression, and click OK.
Note: Repeat Steps 5(b), (c), (d), and (e) for every added field, replacing $feature["<field 2>"] with a preferred field before clicking Test.
The map below displays the office branches in California labeled with their respective office sizes and contact numbers on separate lines.
Related Information
- FAQ: Is it possible to create multiline labels in ArcGIS Online?
- ArcGIS Online: Configure labels (Map Viewer)
- ArcGIS Arcade: Constants
Last Published: 6/10/2021
Article ID: 000025694
