Frequently asked question
What should ArcGIS Earth 1.10.1 users do if they can’t open a PKI authentication KML service?
Last Published: April 29, 2020
When opening a PKI authentication KML service for the first time, ArcGIS Earth may prompt a built-in black log-in window for users to input usernames and passwords. However, it should display the PKI certification window. This is known limitation, and is being worked on.
There are two workarounds:
  •  The first workaround is to close the log-in window, and refresh the KMZ file in Table of Contents. The correct PKI certification window then displays.
  • The second workaround is to sign in to the Portal that is hosting the service first, and then add the KML service again.
Article ID: 000023245
Software:
  • ArcGIS Earth
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
