PROBLEM
The transparent background of images inserted into ArcMap appears as solid white
First Published: May 5, 2016
Last Published: February 22, 2023
The content in this article pertains to retired ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When images with transparent backgrounds are added to an ArcMap document with the Insert > Picture menu option, the image appears with a solid white background obscuring the elements behind it.
Cause
This is a known issue when inserting images with transparent backgrounds into ArcMap.
Solution or Workaround
Open the image using Microsoft Word or PowerPoint, then paste the image into the ArcMap document.
Article ID: 000006388
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
