ERROR
Some features in a time-enabled hosted layer do not show up on a web map in ArcGIS Online
Last Published: December 31, 2021
Error Message
Some features in a time-enabled layer are not visible on a web map when time animation is enabled, even when the time slider covers the whole timeframe,as shown in the following images.
time settings
time-enabled feature layer
time animation enabled
Cause
Features are not displayed on the map that are missing dates and times in the attribute field that is used for the time animation in the feature layer, as seen in the following image.
missing time attributes
Solution or Workaround
To resolve this, you may use any of the following workarounds:
  1. Add dates for all features.
  2. Change the time settings for the layer and use a different date field that has dates for all features.
  3. Disable time animation.
time attributes added
Article ID: 000026817
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
