HOW TO
The Log4Shell vulnerability (CVE-2021-44228) is a critical security vulnerability in version 2 of the log4j library. This article provides steps to mitigate the risk of exploitation. Esri is working towards a patch, but this mitigation script can be used immediately on all versions of GeoEnrichment Server.
Note: A patch is now available for GeoEnrichment Server 10.9.1, for all other versions keep using the mitigation scripts. Please check the ArcGIS Enterprise Log4j Patch Summary Page.
How This Script Works:
This script implements a widely documented industry approach of modifying version 2 log4j libraries to remove the JndiLookup.class file from the “core” log4j jar file so that the vulnerability can’t be exploited. This script identifies all locations in GeoEnrichment Server where the class files reside and then removes those class files. The script has two implementations – one for Linux and one for Windows. These same scripts can be used against ArcGIS Server, Portal for ArcGIS, and ArcGIS Data Store and so if you have downloaded the log4shellmitigation script for those products then you can re-use it for these steps.
Prerequisites:
Note: Esri recommends verifying that you have the correct download before running these scripts. To do so, run checksum on the downloaded zip files and verify that the hash is identical to that shown in the table below. Do not extract the script prior to running checksum. For more information about running checksum, see the following article: How To: Verify an Esri download using the checksum
Operating system | File name | Hash |
Windows | log4shellmitigation.python.zip | 31EC8F0543348498000B7B36E0ED17354EAAE14C3B131ACC3877B6E1918D58F3 |
Linux | log4shellmitigation.linux.zip | DDB01B31CF7B91270DF4410F502B17D42DC21232661400982D500E79C577897B |
Windows Workflow:
The following steps work for any version of GeoEnrichment Server.
Preparation
<full path to Python>\python.exe log4shellmitigation.py --list <geoenrichment directory>
Here’s an example of the command:
"C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe" log4shellmitigation.py --list "c:\Program Files\ArcGIS\GeoEnrichment"
This lists all the files that will be changed. Make note of these locations in case it is necessary to revert the changes later.
Notes: The GeoEnrichment directory is commonly “C:\Program Files\ArcGIS\GeoEnrichment”. If the path to Python or the Server directory has spaces in it, please put quote marks (“) around the path. Note that it is “dash dash list” --list. Missing a dash or inserting a space will cause the command to fail.
Executing the script
Note: For GeoEnrichment server, it is a requirement/prerequisite that ArcGIS Server is installed on the same machine. Please reference: How To: Run the Log4Shell Mitigation Script for ArcGIS Server
<full path to Python>\python.exe log4shellmitigation.py --delete <geoenrichment directory>
"C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe" log4shellmitigation.py --delete "c:\Program Files\ArcGIS\GeoEnrichment"
This is the command that is modifying the JAR files so that log4shell cannot be exploited.
<full path to Python>\python.exe log4shellmitigation.py --delete <geoenrichment data directory>
"C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe" log4shellmitigation.py --delete "c:\geoenrichment"
Troubleshooting
If there are any problems and you wish to roll back the changes, please contact Esri Technical Support for assistance.
Linux Workflow
The following steps should work against any version of GeoEnrichment Server.
Preparation
For example, if GeoEnrichment Server were installed in /opt/arcgis/geoenrichment then you must place the script in the /opt/arcgis directory.
Note: If you have multiple ArcGIS Enterprise products installed on the same machine with the same parent directory and you have already run the log4shellmitigation.sh script from that same location, it is not necessary to run again. Running the script from a parent directory will apply it to all products that share the same parent directory.
chmod 500 log4shellmitigation.sh
./log4shellmitigation.sh -lThis lists all the files that will be modified. No backup of these files will be made by this script. If you wish to back up these original files, do so now by copying them to some other location.
Troubleshooting
If there are any problems and it is necessary to roll back the changes, please contact Esri Technical Support for assistance.
Article ID: 000026982
Get help from ArcGIS experts
Download the Esri Support App
