HOW TO
Remove detached objects (feature classes) from a geodatabase
Summary
In the event of data or users being removed from a back-end database, geodatabase objects are sometimes detached. The most likely causes for this are:
  • The objects were unintentionally dropped by a user with a SQL command.
  • During database migration, the geodatabase objects were lost.
Procedure
The instructions provided describe how to remove a detached object from a geodatabase. Before proceeding with the following workflow, ensure a recent verified and tested backup has been completed.
  1. In the back-end database, use SQL to create a table with the same name as the detached object.
    CREATE TABLE <detached_table_name>
    column_name1 data_type,
    column_name2 data_type,
    column_name3 data_type,
  2. Use ArcCatalog to delete <detached_table_name>.
  3. To add the feature class back in to the geodatabase, create the feature class in ArcCatalog with the same name.
Article ID: 000011812
Software:
  • ArcGIS Desktop
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
