PROBLEM
Note: This article pertains to ArcGIS version 10.0 only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed.
Geodatabase upgrade to version 10 or later fails with the following error message:
Error: Error(Check Datasets): Could not update server tables and stored procedures. Error (-238)
The sde_setup.log shows the following details:
[<timestamp>] Error: DBMS view exists (-238). Tables not converted to DBS. Error: -238 [<timestamp>] SDE release upgrade not completed(-238). [<timestamp>] ERROR installing/upgrading ArcSDE, Error = -238
The physical database view of a geodatabase multi-versioned view for an archiving-enabled feature class is missing. The most likely causes for this are:
The solution to this problem is to identify and delete the detached multi-versioned view entries for archiving-enabled feature classes in the geodatabase schema, as follows:
select owner, table_name, imv_view_name from table_registry where upper(table_name) || '_H' in (select upper(table_name) from table_registry where Upper(table_name) like '%_H') and upper(Imv_view_name) = upper(table_name) || '_MV'
Note: For Microsoft SQL Server use the following SQL statement:
select owner, imv_view_name from sde_table_registry where upper(table_name) || '_H' in (select upper(table_name) from sde_table_registry where Upper(table_name) like '%_H') and upper(Imv_view_name) = upper(table_name) || '_MV'
sdetable -o delete_mv_view -t <table_name>
Get help from ArcGIS experts
Download the Esri Support App
