PROBLEM
Unable to share ArcGIS Survey123 survey and results with an ArcGIS Online group
Last Published: April 27, 2022
When managing surveys on the ArcGIS Survey123 website, surveys and results can be shared to groups created in ArcGIS Online on the Collaborate tab.
However in some instances, an ArcGIS Online group is unavailable in the list of groups to share the surveys and results.
The Collaborate tab on the ArcGIS Survey123 website showing no group to select to share the survey
Cause
The ArcGIS Online group has update capabilities. Groups with update capabilities cannot be used to share surveys or results from the ArcGIS Survey123 website to protect the data, as members of such groups can edit all the items shared with the group members.
The ArcGIS Online group with update capabilities displayed as Shared Update
The recent February 2021 ArcGIS Survey123 3.12 update allows groups with update capabilities to update surveys but not share the surveys and results.
Solution or Workaround
It is not possible to change the update capabilities setting of a group. The only workaround is to create a new group without update capabilities, and invite members to the new group. To create a group without update capabilities, select Only their own items for What items in the group can its members update? when creating the group. Refer to ArcGIS Online: Create a Group for more information.
The Create New Group window showing the 'What items in the group can its members update' option when creating a new group
Article ID: 000024709
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
