PROBLEM
Unable to retrieve users from Active Directory in the ArcGIS Enterprise portal
Last Published: May 26, 2025
The ArcGIS Enterprise portal is configured to use Windows Active Directory for authentication. Although the JSON is valid, testing the connection in the Portal Administrator Directory returns the following error, and searches for users within the directory return no results:
Error:
Failed to connect to the user store.
Code: 500
The error message
Cause
The issue is due to a misconfiguration in the Active Directory identity store settings within the ArcGIS Enterprise portal. The misconfiguration can be caused by various issues, such as a recently reset password or a no longer available user account.
Solution or Workaround
Reconfigure the Active Directory JSON settings. Refer to Portal for ArcGIS: Use your portal with LDAP or Active Directory and portal-tier authentication for instructions.
Article ID: 000036068
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
