PROBLEM
Unable to publish feature classes with a geometric network from ArcGIS Desktop to ArcGIS Online
First Published: November 25, 2020
Last Published: November 25, 2020
When attempting to publish feature classes with a geometric network from ArcMap or ArcGIS Pro to ArcGIS Online, publishing fails, and the following error messages are returned:
In ArcMap
Error:
Error 001270: consolidating the data failed.
In ArcGIS Pro
Error:
Status: Failed StatusMessage: Consolidation failed ErrorMessage: Consolidation failed
Cause
The errors encountered are related to build errors in the geometric network in which the feature classes are involved.
Solution or Workaround
Geometric network functionality is not supported in ArcGIS Online. When publishing a geometric network to ArcGIS Online, the geometric network functionality is no longer available.
To resolve the issue, identify and fix the errors in the feature classes. Refer to ArcMap: Identifying geometric network build errors and ArcGIS Pro: How to access network dataset build errors for more information. Alternatively, make copies of the feature classes without the geometric network to allow publishing.
Article ID: 000024416
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
