PROBLEM
Unable to publish ArcGIS StreetMap Premium data from ArcGIS Pro to ArcGIS Server
Last Published: December 22, 2020
When attempting to publish ArcGIS StreetMap Premium data from ArcGIS Pro to ArcGIS Server as a copy, the following error message is returned:
Error:
Error 003125: Input data is license protected. Copying of this data is not allowed.
Cause
  • The detailed street layers in StreetMap Premium are license-protected. The data must be referenced and cannot be shared as a copy. For more information refer to ArcGIS StreetMap Premium: Technical restrictions.
  • The ArcGIS Server machine's drive lacks space.
Solution or Workaround
Depending on the cause, use one of the workarounds below to solve the issue.
Register the folder containing the ArcGIS StreetMap Premium file geodatabase with ArcGIS Server
ArcGIS Server must contain the StreetMap Premium license extension to publish the data. Refer to the following documentations for more information.
Clear the disk space on the ArcGIS Server machine
Before publishing the StreetMap Premium data, free up space on the drive. Refer to Problem: The volume of ArcGIS Server logs affects performance for more information.
Article ID: 000024582
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS StreetMap Premium 2018
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
