PROBLEM
Unable to print web maps from Portal for ArcGIS Map Viewer
First Published: July 22, 2022
Last Published: November 28, 2024
Attempts to print web maps from Portal for ArcGIS Map Viewer fail and one of the following errors is returned.
Error:
Unable to complete operation.
Error executing tool. Export Web Map Task : Failed to create layer from service. Failed to execute (Export Web Map Task).
Error:
Unable to export
Error:
There seems to have been an error
Cause
  • The PrintingTools geoprocessing service is stopped.
  • The firewall or antivirus software is preventing the service from starting by blocking back-end processes.
  • The browsing cache on the machine is not cleared.
Solution or Workaround
Use one of the methods below to resolve the issue.
When using an ArcGIS Server print service with services added by the members to the portal through HTTPS, additional configuration is required. Any machine that runs the print service must be configured to trust Certificate Authority (CA) signed certificates from the site providing the HTTPS services. Refer to ArcGIS Server: Import the CA root certificate into the Windows certificate store for more information.
Start the PrintingTools service
Navigate to ArcGIS Server Manager > Services > Manage Services > Utilities. Identify the PrintingTools service and click Start.
The image of the PrintingTools service section on the ArcGIS Server Manager page.
Configure the firewall settings
To allow a connection to ArcGIS Server, remove the firewall rule on the machine blocking the connection. Refer to ArcGIS Enterprise: Firewall settings for more information.
Add exceptions to the antivirus software
Ensure the proper exceptions are in place for all the ArcGIS Enterprise directories. Refer to ArcGIS Trust Center: ArcGIS security for more information.
Clear the browsing cache
Clear the browsing cache on the machine to ensure a smooth performance of the browser. Refer to Google Account Help: Clear cache & cookies for more information.
Use a different browser
Use a different browser such as Google Chrome, Mozilla Firefox, or Microsoft Edge to log in to Portal for ArcGIS Map Viewer and print the desired web maps.
Article ID: 000028086
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
