ERROR
Printing a web map from the map viewer in ArcGIS Online fails with the following error returned:
Error: An error occurred while creating the printed map.
Depending on the cause, select one of the options below to resolve this issue:
Use the ArcGIS Server PrintingTools utility service in ArcGIS Online
Note: Only administrators can configure the site's utility services in ArcGIS Online. For more information, refer to ArcGIS Online: Configure utility services.
Use HTTPS in the URL of the web map instead of HTTP and print the web map
If the web map is not configured to use HTTPS, refer to ArcGIS Server: Secure ArcGIS Server communication.
Remove unrelated feature layers or feature services from the web map or use hosted tile layers and print the web map
For more information, refer to ArcGIS Online: Publish hosted tile layers from hosted features and ArcGIS Online: Publish hosted tile layers from files.
Article ID: 000017602
Get help from ArcGIS experts
Start chatting now
