PROBLEM
Unable to load or edit feature classes after creating a geometric network or network dataset in ArcMap
Users granted the select and modify (update, insert, and delete) dataset privileges are not able to load or edit a feature class in ArcMap when a new geometric network or network dataset is created. Attempts to load a feature class in ArcMap return one of the following error messages:
Error:
Error opening feature class.
The table was not found.
DBMS table not found.
Error:
Could not add the specified data object to the map.
Error:
The feature class participates in a geometric network that could not be opened.
Error:
DMBS table not found.
Cause
Creating a geometric network and network dataset generates additional underlying network tables within the geodatabase. Although users are assigned the required privileges to access the dataset, the privileges are not valid for the newly generated network tables.
Solution or Workaround
To solve this issue, revoke and grant privileges to the dataset that hosts the geometric network.
Revoke and grant the privileges in ArcGIS Desktop
Use the Privileges dialog box to revoke and grant the INSERT, UPDATE, and DELETE privileges to the geometric dataset once it is created. For more information, refer to ArcMap: Use the Privileges dialog box.
Revoke and grant the privileges using SQL Server Management Studio
Use SQL Server Management Studio to grant SELECT, INSERT, UPDATE, and DELETE privileges to the underlying network tables. For more information, refer to Microsoft: GRANT Object Permissions (Transact-SQL).
Article ID: 000022700
Software:
  • ArcMap
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
