PROBLEM
Unable to import a certificate in ArcGIS Enterprise
First Published: November 27, 2020
Last Published: April 20, 2022
When attempting to import a certificate via ArcGIS Server Administrator Directory or Portal Administrator Directory, the following error is returned:
Error:
Unable to import certificate. Code: 500
The error message in Portal Administrator Directory
Attempting to import the same certificate via Internet Information Services (IIS) Manager returns the error message:
Error:
The password you entered is incorrect.
The error message in IIS Manager
Cause
This issue occurs when the following conditions are true:
  • The ArcGIS Enterprise software is deployed on a Windows Server 2012 (R2) or Windows Server 2016 machine.
  • The SSL certificate is created as a PFX file using the AES256-SHA256 encryption algorithm.
Solution or Workaround
Perform the workaround below to resolve.
  1. Export the SSL certificate as a PFX file. Refer to Microsoft: To export the .pfx and .cer files for steps to do this.
  2. When prompted to create a password in the Security window, select TripleDES-SHA1 from the Encryption drop-down list.
In the Security window, select TripleDES-SHA1 from the Encryption drop-down menu.
Once the export operation is successful, the PFX file can be imported into ArcGIS Enterprise and IIS Manager.
Article ID: 000024722
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
