PROBLEM
Unable to hide fields in ArcGIS Instant Apps forms
First Published: January 23, 2026
Last Published: January 23, 2026
Fields remain visible when creating or editing a feature in ArcGIS Instant Apps forms even though field visibility is disabled in the layer visibility settings.
For example, the ‘Create feature’ pane below displays the Year and FacilityName fields although field visibility is disabled in the 'Layer options' pane of the Instant Apps Manager template.
The Year and FacilityName fields displayed in the Create feature pane
Cause
The layer visibility settings do not control which fields are displayed in Edit or 'Create feature'. Layer visibility only affects the field display in the attribute table. So hiding fields in 'Layer options' does not hide the fields in the form.
Solution or Workaround
Select fields through form configuration for the layers in Map Viewer
In Map Viewer, configure a form for attribute editing and select the required fields to present them as form elements. Refer to ArcGIS Online: Configure a form for more information. Refresh the existing ArcGIS Instant Apps to reflect the changes in field visibility.
Optionally, configure the form using ArcGIS Field Maps Designer. Refer to ArcGIS Field Maps: Build the form for more information.
Article ID: 000039759
Software:
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
