PROBLEM
In ArcGIS Experience Builder, attempts to modify the calculated fields of an Edit widget are unsuccessful as the field box is not clickable. The Edit widget below shows the non-editable calculated field.
This is a known limitation. When a field is configured with a calculated expression in Forms on the Settings toolbar in Map Viewer, it becomes read-only and cannot be edited in the Edit widget. This restriction applies only to the Edit widget and not to other widgets.
Use the Table widget to edit the calculated field.
 to open the Insert widget panel.
 > Publish.The image below shows the edited field in the Table widget is successfully updated.
Article ID: 000034529
Get help from ArcGIS experts
Start chatting now
