PROBLEM
Unable to display polygon and point feature services when working offline in Collector for ArcGIS (Windows)
First Published: December 12, 2018
Last Published: July 28, 2025
In some instances, when attempting to sync a map to work offline in Collector for ArcGIS (Windows), the point and polygon feature services do not appear on the map.
The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
Cause
This is a known limitation. The problem occurs when using polygon and point feature services published from ArcGIS Pro, and is specific for Windows 10 devices. For more information, refer to BUG-000105146.
Solution or Workaround
To resolve this issue, use one of the following options:
Save the polygon and point feature services in ArcGIS Online
Save each polygon and point feature service in the ArcGIS Online web map to update the JSON of the feature services.
  1. In ArcGIS Online, open the web map containing the polygon or point feature services and save each of them in the web map referring to the web help page, ArcGIS Online Help: Save layer.
  2. Save the web map again and enable the layers and map for offline use.
After the polygon and point feature services are saved, sync the web map to work offline in Collector for ArcGIS (Windows).
Use ArcMap to publish the polygon and point feature services
Publish the polygon and point feature services from ArcMap referring to the following web help page, ArcGIS Online Help: Publish from ArcMap. Use the published polygon and point feature services to create a web map and sync the web map to work offline in Collector for ArcGIS (Windows).
    Article ID: 000019220
    Software:
    • ArcGIS Collector
    • ArcMap
    • ArcGIS Pro
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
