PROBLEM
Unable to display or configure elements in ArcGIS Dashboards
First Published: April 27, 2021
Last Published: April 27, 2021
When viewing or editing the ArcGIS Dashboards app, elements in the dashboard and the configuration window of the element load indefinitely.
Elements in the dashboard load indefinitely.
The element's configuration window loads indefinitely.
In some cases, the elements in the dashboard display a message, ‘Data source error’, and a warning icon, 'Cannot access data'.
The element displaying a message and warning icon.
Cause
In a dashboard, elements such as map legends, serial charts, pie charts, indicators, gauges, lists, and details are data-driven and rely on the underlying data source’s ability to generate feature information. However, elements in the dashboard fail to display information due to the following causes:
  • The element in the dashboard loads indefinitely when it draws data from a web map configured in the map element, and the map element is collapsed to the size of 0%.
  • A return message and warning icon are displayed when the referenced operational layer of the map configured in the map element is removed at the web map level.
Solution or Workaround
Depending on the cause, use one of the following options to resolve the issue.
Resize the map element to load the dependent elements in the dashboard
Resize the map element to display it and load the dependent elements in the dashboard.
  1. Log in to ArcGIS Online. Click Content > My Content.
  2. Browse to the dashboard, click More Options The More Options button., and select Edit Application.
  3. In ArcGIS Dashboards, depending on the location of the map element, resize it to the desired size. Refer to ArcGIS Dashboards: Resize an element for more information.
  4. On the top panel, click Save The Save button. to save the dashboard.
Configure the element to draw data directly from the layer
Configure the element to draw data directly from the layer in the Other layers section in the element’s configuration window.
  1. In ArcGIS Dashboards, hover over the top-left corner of the element, and select Configure The Configure button. in the drop-down menu. In the example below, the ‘details’ element is configured.
  2. In the Details window, in the Other layers section, click Browse all layers.
  3. On the My layers tab, browse to and hover over the layer, and click Select.
The hosted feature layer selected as a reference layer in the element.
  1. In the Details window, configure the element, and click Done.
  2. On the top panel, click Save The Save button. to save the dashboard.
Add the layer to the web map in Map Viewer
In Map Viewer, add the layer to the web map, and configure it as the reference layer of the element in ArcGIS Dashboards.
  2. In Map Viewer, add the layer to the web map.
    1. On the My Content page, browse to the web map, click More Options The More Options button., and select Open in Map Viewer.
    2. In Map Viewer, on the left panel, on the Layers tab, click Add layer.
The hosted feature layer added in the web map to be configured as the underlying layer.
  1. In the Add layer pane, browse to the layer, and click Add The Add button. to add it to the map.
  2. On the left panel, click Save > Save to save the map.
  1. In the upper-left corner, click the Home drop-down list, and select Content.
  2. On the Content page, on the My Content tab, browse to the dashboard, click More Options The More Options button., and select Edit Application.
  3. In ArcGIS Dashboards, configure the layer as the reference layer of the element.
    1. Hover over the top-left corner of the element, and select Configure The Configure button. in the drop-down menu. In the example below, the ‘details’ element is configured.
    2. In the Details window, under Layers from ‘<map_name>’ map:, select the layer.
The operational layer of the map selected as the reference layer of the element.
The image below shows all the elements displaying the feature information in ArcGIS Dashboards.
Elements in the dashboard displaying the information in ArcGIS Dashboards.
Article ID: 000025511
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
