PROBLEM
Unable to delete records of selected features in the Table widget for ArcGIS Experience Builder
Last Published: October 24, 2024
In ArcGIS Experience Builder, the option to delete records of selected features from a Table widget is unavailable.
The image below shows a published experience with a Table widget, where a selected feature is chosen, but the option to delete records is unavailable.
A Table widget without the option to delete records in ArcGIS Experience Builder
Cause
This is expected behavior. When a Table widget's data is configured to ‘Selected features’ in the ‘Sheet configuration’ panel, an action in the Map widget is required prior to querying the table in ArcGIS Experience Builder. Hence, the option to delete records is unavailable.
Solution or Workaround
To resolve this issue, add an Edit widget to the experience to display the option to delete records of the selected feature.
  1. Open the web experience in ArcGIS Experience Builder.
  2. Click Insert The Insert button to open the Insert panel.
  3. Add the Edit widget and select the preferred feature layer as the widget's data source.
    1. In the Insert widget panel, on the New tab, under Data centric, drag the Edit widget onto the canvas.
The Insert widget panel
  1. On the Content tab, click New editable layer.
The Edit panel
  1. In the Layer configuration panel, under Data, click Select data.
The Layer configuration panel
  1. In the Select data panel, select the preferred data. In this example, Points_Italy is selected.
The Select data panel
  1. In the Layer configuration panel, under Capability, ensure Delete records is enabled.
The Layer configuration panel with the option to Delete records enabled
  1. Save, preview, and publish the web app.
  2. Open the published web app and click the preferred feature to delete on the Map widget.
  3. In the Edit widget, click Delete to delete the selected feature.
The image below shows a published experience with an Edit widget, where a selected feature is chosen, and the option to delete records is displayed.
An Edit widget with the option to delete records in ArcGIS Experience Builder
Article ID: 000033889
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
