HOW TO
Delete ArcGIS Survey123 records in ArcGIS Experience Builder
First Published: January 3, 2024
Last Published: January 3, 2024
Summary
On the ArcGIS Survey123 website, survey owners and collaborators with certain privileges can view and delete the results of submitted survey responses on the Data tab. Refer to ArcGIS Survey123: View all data for more information. However, survey records can also be deleted in ArcGIS Experience Builder web apps, which is an alternative method to access and delete survey records for the purpose of removing unnecessary or incorrect records to ensure data accuracy.
This article provides two methods to delete ArcGIS Survey123 records in ArcGIS Experience Builder.
Procedure
In ArcGIS Online, enable the editing and delete options for the ‘What kind of editing is allowed?’ setting on the survey’s feature layer. Refer to ArcGIS Online: Manage hosted feature layer editing for more information.
Delete ArcGIS Survey123 records in ArcGIS Experience Builder using the Edit widget
  1. Open the web app in ArcGIS Experience Builder.
  2. Add the Map, List, Feature Info, or Table widget to the web app and select the survey’s feature layer from ArcGIS Online as the widget’s data source. In this example, the Table widget is added, and the ‘Sydney Bird Sightings’ feature layer is selected as the data source.
Adding the Table widget and setting the data source in the ArcGIS Experience Builder web app
  1. Add the Edit widget with the ‘Attribute only’ mode and select the survey’s feature layer as the widget’s data source.
    1. Add the Edit widget to the web app.
    2. On the Content tab of the Edit widget, select Attribute only and click New editable source.
    3. On the Layer configuration panel, click Select data and select the survey’s feature layer. In this example, the Sydney Bird Sightings feature layer is selected.
Setting the data source of the Edit widget
  1. Under Capability, toggle Delete records on.
Turning on the Delete records toggle button in the Layer configuration panel
  1. Save, preview and publish the web app.
  2. Open the published web app. Click on a record in the widget from Step 2 and the selected record is displayed in the Edit widget.
  3. In the Edit widget, click Delete to delete the selected record.
Deleting the selected record in the Edit widget
The image below shows the deleted record in the ArcGIS Experience Builder web app is also deleted on the Data tab on the ArcGIS Survey123 website.
A comparison of the survey records before and after deleting a record in ArcGIS Experience Builder
Delete ArcGIS Survey123 records in ArcGIS Experience Builder using the Embed widget
  1. Sign in to ArcGIS Online.
  2. Create a web map with the survey’s feature layer and enable pop-ups. Refer to ArcGIS Online: Get started creating maps (Map Viewer) and ArcGIS Online: Configure pop-ups (Map Viewer) for more information.
  3. Save the web map and copy the URL.
Copying the URL of the web map
  2. Embed the web map from Step 2 in the web app.
    1. Add the Embed widget to the web app.
    2. On the Content tab of the Embed widget, select the URL option for the Embed by parameter and paste the copied URL into the text box.
Pasting the copied URL into the Embed widget text box
  2. Open the published web app and click a feature on the embedded web map.
  3. In the selected feature’s pop-up, click the Edit The Edit icon icon. The Edit feature pane is displayed.
The Edit icon in the pop-up of the selected feature
  1. Click Delete to delete the selected feature.
The Delete button in the Edit feature pane
Article ID: 000031663
Software:
  • ArcGIS Experience Builder
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
