PROBLEM
Unable to create True Orthos from RGB images in ArcGIS Drone2Map
First Published: January 13, 2025
A True Ortho is an orthorectified imagery product fully corrected to display a nadir image. This product is created as a three-band RGB (red, green, and blue) or single-band thermal image in TIFF format, using the project’s coordinate system. In ArcGIS Drone2Map, when using the RGB drone imagery to create a True Ortho product, the camera model fails to compute and returns the following error message:
Error:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (https://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (ComputeCameraModel).
Image of the processing log
Cause
This behavior is caused by incorrect use of the camera model's information from the drone during processing of the 2D product. Accurate information is required for the software to properly align the imagery to the elevation surface.
Solution or Workaround
  1. Open the project in ArcGIS Drone2Map.
  2. On the Flight Data tab, in the Manage group, click Edit Camera.
  3. In the Edit Camera Parameters pane, for Camera Source, select Image Metadata from the drop-down list.
The Edit Camera Parameters pane
  1. Click OK.
The Image Metadata option populates all of the image parameters from the drone, which includes essential information such as the camera model, focal length, and sensor pixel size. Restart the True Orthos processing when the camera parameters are populated. Refer to ArcGIS Drone2Map: Use the 2D Products template for more information.
Article ID: 000034302
Software:
  • ArcGIS Drone2Map
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
